Last edit by: IB Advertising
Thug Style / Club Style Dyna pic's
http://www.hdforums.com/forum/dyna-g...yna-pic-s.html
ISSUE
Member Lama is in the process of modding his 2007 FXDC into a club style or thug style bike (known today as outlaw bikes) Asks members to provide inspiration and post pictures of their own bikes. Members show off their bikes.
Read below for the full discussion…
ISSUE
#2961
The ride is ENTIRELY different. Although the bars are only about 4" lower, the are back about 4" too. The control is rigid and precise; making it a lot easier to speed through twisties.
My fairing should be ready any day now, and my Powder-Pro hand guards should arrive soon.
+1 on the precision on the control switching from apes to a rigid setup.
Interested to see it with the fairing, although I think it looks cool without.
#2962
Anyway, the only advice I have for swapping to MX bars is to make sure the holes for the wires are big enough. I had Jim from Forbidden drill for wiring, but I spent a good deal of time with a Dremel making the holes big enough. Even then, they are a tight fit at the 7/8" part of the bars by the grips.
I did a stupid thing putting my grips on too. I sprayed adhesive into the throttle grip and slipped it over the throttle tube. Half way through my test ride, my throttle got REAL tight. I didn't realize the throttle tube had a small hole at the outer end. Sone adhesive got under the tube and gummed it up. It cleaned up with disassembly and a coat of graphite. Lesson learned. Install the grip to the tube and let it dry before installing the throttle.
#2970
I need a seat recommendation from some of you guys. I need a 2up seat that is similar styled as the stock fxdx seat. Something that tapers down in the passenger section but has a deeper rider bucket area. I have several harleHarley seats now and mostly use the stock fxdx seat. The rider bucket area isn't deep enough and I slide back to much when I get on it.
