shifting without the clutch
Hypothetically, if your clutch fails for some reason while out on the road, does anyone know how these modern Dyna tranys react to shifting by just using throttle control to switch gears ? How many gears can you safely go through ?
I know getting into 1rst would be interesting but wondered if you could nurse your bike home without grinding off too many teeth in the process.
This could be good information in an emergency.......
Years ago we drove around in VW Beetles often not using the clutch at all, for no good reason of course, other than we were young and rebellious.
Thanks guys for any input.
I know my '99, while no spring chicken for sure, handles it alright - yeah first would be tricky - but I managed to roll the sweet spot on the throttle ok and it just slipped into gear on the way up, a little more of a sudden insertion on the way down but I didn't worry me any. One of the first things I did when I rode it home was see how the bike handled a few different "Oh s#!%" scenarios.
I've done that quite often on my 07 streetbob...obviously with clutch on take off but clutchless changes can be done..its a matter of knowing the bike and actually how to do it..not a newbie thing.... if my clutch cable broke out on a ride I'de get home so long as I did'nt hit traffic lights etc
It will do fine, but I would only do it as an emergency. I hear tell that the shifter forks in the newer bikes are not that robust. But if you get your rpms right, shifting is no problem... up or down. Starting out would be a problem....
It's actually very easy to shift without the clutch, all you have to do is match RPM to the gears, in others words...To upshift ease off the throttle as you gently shift, when the speed and RPM match it will go into gear.
To downshift you rev the motor slightly until it slides into the lower gear. Even first is not difficult once you figure out how to match gears. This why blipping the throttle is a regular occurrence when downshifting, even with a clutch for a lot of riders. It's not just trying to be cool, it helps the gears match.
Only problem is if you have to come to a complete stop, but if you are driving ahead that too can often be overcome.
Sequential gearboxes of the type found in bikes work differently to manual car 'boxes. Going up the box usually isn't a problem, it's simply a case of take the revs up and then close the throttle keeping a slight pressure on the shifter pedal and it'll pop up a gear when the revs match.
Coming down the box is a bit more tricky because there's no neutral that you have to pass through where the revs of motor and 'box can be matched so it requires a lot of practice which can result in bent selector forks. If you really must change gear without using the clutch, save it for upchanges and be aware of the damage you can do on downchanges when you get it wrong.
Derv
Derv
