Tank Badge removal
Old 06-28-2006, 04:08 PM
rob_will's Avatar
rob_will
rob_will is offline
Default Tank Badge removal
I want to remove the tank badge from my 06 Black Cherry Street Bob, but I don't want to damage the paint. Has anyone done it? and if so how?
Old 06-28-2006, 04:14 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
Default RE: Tank Badge removal
I peeled mine off yesterday while it was sitting in the hot sun. Be careful, the edges are sharp.
Old 06-28-2006, 04:18 PM
dog06bob's Avatar
dog06bob
dog06bob is offline
Just pull from one end. The tape started to come with it when I pulled on the emblem so I pulled it by the tape. It all came off in one piece. If all the tape doesn't come off use GooGone to remove it. It is safe for the paint. I used it to take off the tape from my refectors on the rear fender. The emblems bend real easy, so don't plan on putting them back on.
Old 06-28-2006, 04:20 PM
ReeseSS's Avatar
ReeseSS
ReeseSS is offline
Take a length of mono fishing line, tie a loop at both ends for handles, and just start working it back and forth as your pulling across behind emblem. Charcol fluid will take off residual stickum, but wax afterwards, it won't hurt paint, but will strip the wax
Old 06-28-2006, 05:09 PM
wild wally's Avatar
wild wally
wild wally is offline
ditto on goo gone. Squirt it in the cracks before you even start and let it soak in for a while, it will soften it up for you.
Are you going to replace the stock emblems with another emblem?
Wally
Old 06-28-2006, 06:31 PM
veniculum's Avatar
veniculum
veniculum is offline
fishing line works...also dental floss...the glide stuff is great...very smooth. Use a hair dryer if it's cold....and after the emblem is removed, I agree..the goo gone stuff is great and won't harm your paint.
Old 06-28-2006, 06:35 PM
stbobber's Avatar
stbobber
stbobber is offline
Why do you want to remove the tank badge? I thought about doing the same, do you think it looks better?
Old 06-28-2006, 07:01 PM
CraigC's Avatar
CraigC
CraigC is offline
Just start from one end and peel it off. Put some tape under the other end to keep it from scratching the paint when that end comes off. Be careful, the badges are stamped sheet aluminum and pretty sharp. 3M Adhesive Remover also works well to get any residual adhesive off the paint. IMO, fishing line or dental floss is an unnecessary hassle when the adhesive is still fairly new, i.e. soft and pliable.
Old 06-28-2006, 07:02 PM
hd_sob's Avatar
hd_sob
hd_sob is offline
my reasons:
1-its a cheap-looking piece 'o crap
2-when i wipe off the tank the damn cloth always gets snagged on it
3-every time i see CraigC's sig pic i get jealous
4-its more 'bob' without it
Old 06-28-2006, 07:14 PM
stbobber's Avatar
stbobber
stbobber is offline
you got a point, think I'll remove mine also.
Quick Reply: Tank Badge removal
