Power Commander III Fitment Question
pc 3 list different part numbers for different models
but the unit inside is common to a wide range of the different "kits"
you just need to make sure that the kit listed for your model contains the same "unit" as the the kit for the other model
in the case of 07 touring versus 06 dyna, I would think the base unit is prob the same, but you just need to check
Just an FYI for everyone... The main difference between hd models for the power commander III is the map that comes installed on them. I had the power commander for an 07 touring put on my 06 dyna Screamin Eagle build and it fits - and runs perfect. dyno tuned... oh yea. 09Dynaman had it right... in 2008 however, everything changed.
xmeter
04-14-2008 12:20 PM
Dogwood
11-16-2007 02:26 PM
07, 2007, commandcer, commander, difference, differences, dyna, fitment, glide, iii, power, question, review, touring, wide
