windvest on bobber
windvest on bobber
I put a windvest on my streetbob bagger - LOL. I have set it up in line w/ the forks but find the wind ratteling my helmet. Since it's pouring and I'm not riding in anymore storms less I have to, what the best way to adjust it? Should I push (angle) the top out a bit or raise it? It looks like it has one more hole in the shield above the bracket. I am not sure how many are hidden under the bracket. I can also reverse the "P" clamp so that the leg is on top instead of the bottom as shown in the directions. Oh, I'm 5'-9"....almost and I have the standard 14 x14. Thanks, [sm=crossbonesgif.gif] MAko
RE: windvest on bobber
Adjust the height til you can still easily see over the top. You probably need to move the shield up one inch,that's all the adjustment you have. Keep tilting the top forward til the helmet buffeting goes away, probably forward an inch and a half when measured at the top of the arc. Once you get it adjusted you'll still have plenty of wind hitting you but the buffeting will go away. A tank lift helps, seems to direct more air down instead of up and over the tank and right into your nostrils. A small windshield bag at the base of the shield also blocks of some of the wind.
Good Luck
Tom
Good Luck
Tom
ORIGINAL: makoshark333
Cause for long trips with lots of rain and a half helmet, I have pussed out in my old age. Something about creature comforts for the long haul! Mako
The shield sits kinda low....probably around my neck height. Took short spin b/t the rain and it buffeted my helmet but nothing in my face. To adjust the height, do I turn the P-brackets so the leg is on the top? Also. the winsheild cross bar is mounted and there is a plug in a hole above it. If I use that hole it will drop the shield. It almost looks like it's on it'slowest setting unless there is another hole under the mounting plate. Do you think rotating it out is the answer and what is the effect if too far out. I never road w/ a sheild b/4. What is a tank lift? Mako
Yes, the leg should be on top. Mine is adjusted up one inch and there is one hole exposed which I covered with the little chrome plug that comes with the windshield.. Sounds like yours is already adjusted up. Take it apart,you can tell.
Once you get it installed correctly, just loosen the allen bolts on the part that clamps to the bars and push forwars a little bit, tighten her back down, ride and adjust til you get the best adjustment for you.
Tank lift moves the front of the tank up to a max of three inches with a home made, or purchased kit. Do a search,there's a million posts on it.
Good Luck
Tom
[IMG]local://upfiles/8936/0E7ECBC1844A460D9CD82A394567B17B.jpg[/IMG]
Good Luck
Tom
