Run / Brake Module - Photos?
Many years ago when I got my Street Bob I had the dealer install the "Run / Brake" module, or whatever it's called, so my rear indicators would light up when I hit the brake.
I am pulling my rear signals off and going with an integrated tail light option so I figured I should take off the module as well. I'm guessing it is one of the many plugs under my seat but I have no idea what I'm looking for.
Does anyone have this installed and would be willing to give me an idea of what connection I want to take out of there?
Also, I seem to remember when I originally swapped out my stock brake light for an LED one that the turn signals plugged into the tail light housing. I'll go down and pop my cover off to make sure, but does that sound correct?
when i get home from work i will take a pic for you. it should be right under your seat, it should be easy to see when you take your seat off. it is a little black box 1in.x1in. with a wire and boot connector coming out of each side. then it piggy backs on your wiring harness. for some reason i remeber it has writing on the side stating what it is (light,brake, mod) or something. when you find it just unplug it from both sides and re-connect the wire harness back together. jackyl
+1...
A few weeks ago I posted some info (+ image + link to instruction sheet from the database) how to install the module in this post:
https://www.hdforums.com/forum/5794453-post5.html
I'd say: work the other way around to have it removed.
They connect under the taillight cover into the black circuit board as shown in this post by mud:
https://www.hdforums.com/forum/4277699-post1092.html
FXD2003Rider
