Someone explain to me how the forks work (shocks)
Old 09-29-2009 | 11:32 AM
Afishinado's Avatar
Afishinado
Default Someone explain to me how the forks work (shocks)
My 99 FXDWG had 2200 miles on it when I bought it 2 years ago. I replaced some of the rubber on it, tires, handle bar bushings... I also replaced the shocks, get off the bike and it stayed squatted down! Anyway, it seems to me the front end compresses too easily, like the 'shocks' were shot. They'll 'bottom out' on too small a bump it seems. The bike also feels a little squirrely to me (but I've been riding the FLHR some), considering adding the dog bone brace, but have to mess up the pretty caps on the chrome front end, if I can even fit them... So is there something I can check before I bring it to a stealer?
Old 09-29-2009 | 12:33 PM
Afishinado's Avatar
Afishinado
Never mind.... Looks like I need to check the oil level first. SEARCH is your friend LOL
Old 09-29-2009 | 07:28 PM
pennetta's Avatar
pennetta
Sounds like a spring issue as the ride height is not affected by the oil level or viscosity. The springs absorb shock and maintain the ride height. The oil only dampens, or slows the reaction to the springs compression.
You say you replaced the shocks, which implies the bolt off rear shocks, but you speak of the front end. Are the front and rear shock components stock?
Old 09-29-2009 | 09:04 PM
Baeseman1's Avatar
Baeseman1
Here's my suggestion. Don't even waste your time 'checking' the fork oil level. Pull the little drain screws on the bottom of the forks and change the oil. You could even measure the oil coming out of each fork to see if it was 'balanced.'
I bought BelRay 15w Fork Oil from my local metric shop instead of the HD mystery weight fork oil. 1 liter was enough for both forks.
Old 09-29-2009 | 09:52 PM
joe.1955's Avatar
joe.1955
When I bought my '08 Wide Glide, I was very disappointed in the softness of the front suspension. Hit a rough spot in a corner and the front end over reacted and got squirrely.
If I just rolled the bike forward a couple of feet and grabbed the front brake, the front end would dive about four inches.
I changed to the Screamin' Eagle fork oil and it helped, but still got weird when hitting the twisties hard.
Installed Progressive springs and 20 wt. fork oil. Rides pretty stiff but handles extremely well in the turns.
Old 09-29-2009 | 09:56 PM
yoseppi's Avatar
yoseppi
You make it sound so easy to drain the forks, but how do you properly fill them back up?
That's one thing I have never done.
Old 09-29-2009 | 10:19 PM
Baeseman1's Avatar
Baeseman1
On my 05' WG, it really is that easy. Drain the oil, replace plugs, pull the fork caps off, dump the oil in (??oz per the manual), replace fork caps.
I believe 06' and newer don't have drain plugs anymore. Also, some models have the spring tention on the fork cap. Best to lift the front tire off the floor (bike jack) and be really careful with the last few threads on the fork cap as they are still under some spring tention.
Old 09-30-2009 | 03:33 AM
fastkevin's Avatar
fastkevin
On a ten-year-old bike, if you're not aware of the fork oil being changed, you need to do it no matter what else you do. If you're going to do it yourself, you need to first get the oil viscosity and level from the service manual. If they're damping rod forks, they're pretty easy to do, but you should take 'em off anyway. When you're checking to see what the correct oil level is, you need to pay attention if it's measured with the forks compressed(usually the case). Sometimes they just tell you the amount to put in, as opposed to the correct height, which is easier to do, just less accurate.
After you put the oil in, you need to work the action on the forks to release any air that got trapped in, then button them back up and re-install 'em. If they're cartridge forks, you'll wanna have the dealer do 'em.
Old 09-30-2009 | 07:49 AM
Afishinado's Avatar
Afishinado
I replaced the rear shocks, never touched the front end. I bought the bike in 07 and pretty much only did what the previous owner did, add more bling (except I ride it a lot more than he did)... It has a chrome front end, and I assUme it is H-D... I won't see the bike until November when I get back to FL to see if it has drains. Does it look like it has stock chrome H-D tubes with drains?
Attached Thumbnails Someone explain to me how the forks work (shocks)-2211038_5.jpg
Sweforty8
03-05-2014 03:00 AM
atrain68
07-14-2011 09:42 AM
Holster Maker
EVO
10-08-2010 01:50 AM
ron1026
09-21-2009 05:38 PM
davidc
08-10-2006 07:58 AM
Quick Reply: Someone explain to me how the forks work (shocks)
