Dyna Lift Blocks - Whoa!
Old 09-22-2009, 01:23 PM
skullcrusher's Avatar
skullcrusher
skullcrusher is offline
got the same lift with the same separation problem. I agree using it is a gamble. Be careful.
  #52
Old 09-22-2009, 03:39 PM
rbartick's Avatar
rbartick
rbartick is offline
Originally Posted by heavydutyt
I have a lowered 2003 wideglide and i looked at a lot of jacks and the scary lift blocks and found the $69 harbor freight yellow jack has bolt on pad rails if you move the rails to the out side it works great and no blocks or 2x4s
Do you mean this one?
http://www.harborfreight.com/cpi/cta...temnumber=2792
The online manual does not say anything about the ability to move the padded rails.
  #53
Old 09-22-2009, 04:34 PM
heavydutyt's Avatar
heavydutyt
heavydutyt is offline
yes that is it the pads unbolt and move in or out i moved mine all the way out i will take a pic and try too post it mine picks up at the rear peg mount and in front of the kick stand spring cross
  #54
Old 09-22-2009, 04:54 PM
heavydutyt's Avatar
heavydutyt
if you look close at your ad pic you can see the bolts at the pads 4 bolts
  #55
Old 09-22-2009, 05:57 PM
ackman1968's Avatar
ackman1968
ackman1968 is offline
Originally Posted by rbartick
That was sarcasm, we all know high dollar and Harbor Freight should never be used in the same sentance.
Originally Posted by Wonkaboy
I have the same jack and can't even get it that far under never mind the blocks, maybe because i have 11 inch shocks ? i can get where it does go on enough to spin and clean the back wheel..
Get some 2X6 scraps and run the bike onto them before you slide the jack under (one for the jiffy stand also). Makes a world of difference.
  #56
Old 09-22-2009, 09:46 PM
JaronB's Avatar
JaronB
JaronB is offline
Originally Posted by ackman1968
Where the hell were you guys with the info on the J&S when I bought my high dollar Harbor Freight Jack????? I'm sure between the adapters and the jack I could have been real close to a good one. Oh well, it works and until it fails or scares the **** out of me I'll keep using it.
Rich is going to buy a J&S after he messed with mine. I think he has the yellow harbor freight jack. After I raised my bike all the way and he tried shaking it and he was sold because it didn't move. It cuts out all or most of the what if's.
  #57
Old 09-23-2009, 05:40 AM
Wonkaboy's Avatar
Wonkaboy
Wonkaboy is offline
Thumbs up
Thanks for the info
  #58
Old 02-01-2010, 06:21 PM
09B29's Avatar
09B29
09B29 is offline
Originally Posted by dogcop727
the blocks are junk. i stopped using mine. i made a new set out of 2x3 and wrapped them in velco and also put velcro on lift. works great and its cheep.
got any pics of the 2 x 3 setup?
  #59
Old 02-02-2010, 02:53 AM
t_b0ne3's Avatar
t_b0ne3
t_b0ne3 is offline
I have the Craftsman yellow all aluminum lift with removable 2" lifts,I ussually take the rear out and leave the front in? I still strap it down but don't have to bother with building anything else?
  #60
Old 02-02-2010, 03:24 AM
Jeff W's Avatar
Jeff W
Jeff W is offline
hell, Fabricate some blocks, How hard can that be? and then set the bike up on the blocks, measure between the blocks side to side and fasten them together with flat stock to keep them from flipping over sideways..what im seeing in that pictures seems to be a very simple fix, From what i can see anyhow. Just looks like the blocks needed to have a wider bottom on them for a bigger foot print on the stand, so that they couldnt flip over on thier sides.
Quick Reply: Dyna Lift Blocks - Whoa!
