View Poll Results: What kind of fuel is everyone running?
Regular
3.18%
Mid-Grade
3.18%
High Test
147
93.63%
Voters: 157. You may not vote on this poll
#54
quart tranny fluid for the primary...3 quarts oil for oil change.
Not debating or trying to start a debate but...I'm 99% sure I read in the SM that for the primary you use tranny fluid.
#56
#57
Yeah, aren't all HD's chain drive primary? When I recently went to purchase fluids for changing...they gave me 1 qt tranny fluid for the tranny...and one
That must be because you are buying HD's tranny/primary blend. I've always felt that one of the nicest things about having three seperate compartments for lubrication, means we can choose which ever lube we feel will do the job best in each area. For me that means, heavy gear lube in the transmission, ATF in the primary, and a good quality synthetic motor oil in the crankcase.
#58
This just reminded me of something. Buena Park PD(the arm pit of the southland) recently switched to HD's, and immediately started experiencing FI probs. The local dealer asked one of the officers if they were in fact using 91 oct, to which the officer responded that they're using whatever the city yard has in their tank. IIRC, the dealer threatened to kill the warranty on their bikes unless they committed to using 91.
Someone at the dealer told them it was to blame for all the off idle stumbling and even the stalls they were experiencing(a service writer at the same dealer asked me if my XR was a Kawasaki)
In any event, they switched to Honda's shortly thereafter. Don't know if that was the cause or part of it...
#59
Well thanks to this thread i gassed up with 89 octane instead of 91 just to find out how it would go. I didn't notice any big changes for about 50 miles,then realized she was running- well my best description would be...a little muffled. That's power-wise heeheehee not sound! So at that point I take a look at the trip meter and zonXX half the tank was almost gone,and we all know the top half is bigger than the bottom. So i save maybe 1.25$ on the fill-up but the gas was gone a whopping twice as fast. At 1/4 tank I refilled with high octane,it got better, and the next tank should be even better so my advice= stick to the higher octane gas. I think i shall even try the 94 for a couple tanks to try that out,but I hear it is a waste with only a stage 1 installed.
