Will these Fit?
Will these Fit?
I already posted a question about relocating front signal to the forks on my 08 Fat Bob, the problem is that the bolts that hold the forks in place are recessed. These are for a VROD and was wondering if they would work. They are from JP Cycles, number 320-209. Please let me know what you guys think.
They look good!
Important to know is:
What thread is used on the VRSC tripple tree and compare it to the bolts used in the tree at your bike. You could post a question in the VRSC section; I'd be surprised if there's nowone who could give you this info out of a VRSC parts catalog.
I checked JP Cycle's site but they don't give any specs on this part.
Send them a mail and ask them for the specs on the thread, the diameter of the thicker part and lenght of the stand-off's.
Good luck,
FXD2003Rider
Good luck,
FXD2003Rider
has been posted some where for a simple way to move them the bracket that is under your left mirror holding the light on is used if you drill out the mounting hole to fit the tripple trees bolt it will fit in the recess you can purchase or maybe get one free from the dealer for the other side check the under 50 mods section https://www.hdforums.com/forum/dyna-...ml#post2666240
The item pictured would work IF the pinch bolts were aligned at the 3 o'clock.
I used this type of bracket for mine (this one is fro 41mm tubes... if you search around you can find some for 49mm tubes):
http://cgi.ebay.com/ebaymotors/Harle...=p4506.c0.m245
On my 08 FXDF the trip tree pinch bolts are aligned off the 4 o'clock position, as viewed looking straight down over the top.
relocate fronts to lower fork tree with existing hardware.
I noticed that the left side hardware on handlebar will bolt on with a little drilling so i got another one for the right side and powder coated with the sigs. Found some small wheel brake cylinder boots at Napa part #82833 and cut one in half. here's one assembled and one ready.
and installed
and installed
ball receptable, left p/n 67829-88
clamp ball stud p/n 67827-88A
ball stud p/n 67822-88
jam nut p/n 7744
kirk180
04-25-2011 09:01 AM
