Lowering an '09 Street Bob
Hey all you Dyna riders out there! This short legged girl needs some helping finding a way to lower my Street Bob about an 1" I'm not having much luck. The only thing Harley has is new shocks but they will only lower a Street Bob 1/4" I have a hard time backing it up sometimes because I'm so darn short.
I love my new bike. Had a Sportster for a year and traded up this spring. It's a bad lookin bike. This girl loves lookin tough on my bike. Don't like girly things. Skulls rule!
Any suggestions out there?
here ya go, try these. good luck!
http://tamarackmw.com/tamarack_046.htm
as stated above, if you dont want to drop the coin on the front suspension you can slide your forks into your trees a bit, just make sure that they are even. Tarmac lowering kits work great... if she is a little girl you can always get away with cuttin a coil out of the shock. take it apart, cut a coil, then grind it flat... put it back together... that is what i am doing on my wifes cafe build... cheap and easy
I put these on my '08 Street Bob. I'm a little under 5'-4". They helped a lot in getting me a little more flatfooted. That plus a custom seat that was a little lower, a little narrower in the front, and new boots that are slightly higher than my old ones. It's perfect now! Oh - and I didn't lower the front end. Not to say that isn't a good idea, I just haven't done it. The installation went pretty easily. Didn't hear hubby swearing TOO much!!
