V&H Short Shots Backfiring (anyone ever resolve?)
Way too loud for me personally too. That's why I got the quiet baffles (forgot to mention that in the original post),
Greetings,
Well...I've run these pipes on my last 4 bikes now...and no popping at all. I don't use the FuelPak as I know of too many people having issues with it. I have always used the SERT and never have had a problem. Yes it's a little bit more money, but well worth it and the bike performs a lot better. No starting or popping issues at all.
Which map are you running? Did you have it dynoed or is an unmodified map?
I just ordered some short shots yeaterday. I didn't get the quiet baffles. I'm going to see how loud it is first. Are the short shots with the quiet baffles still substantially better sounding and louder then stock exhaust?
Yeah, I was going to say that the only way to guarantee no or minimum pop is via a more sophisticated system. I solved my pop by using a TTS, which is SERT like plus tuning aids. It popped pretty good without.
Although leaky gaskets or fitting are the typical culprit, there are stubborn bikes that need closed throttle enleanment and perhaps timing adjustments to get rid of the pop.
vh quiet baffles only reduce sound by 3 decibels or so, not much difference from the regular ones, anything is better sounding than stock
They are not quiet as some have already said, but they deepen the tone and make it sound much better.
Stock V&H baffles sound hollow or tinny to me...the quiets make the bike sound powerful.
FWIW - I went to V&H website and used their recommended settings. You may want to check this because they use 2 different "maps" quiet baffles and standard baffles for our setups. Maybe the dealer put in the wrong settings??
Edit: Another thought it to try and recalibrate your throttle settings. I did this once and it helped greatly. I think it's mode 21. Start with the throttle closed should read 0 move it all the way to full throttle smoothly and it should read 99 let it return to closed throttle smoothly.
Edit for my edit: calibration mode is 19 and you check the settings in mode 21 - 0 closed 50 around half throttle and 99 full throttle.
