Stripped a hex nut. Now what??
Trying to replace the upper belt cover with a chrome one. The front hex nut got stripped trying to take it off. Now. nothing works.
How can I get it out?
Interestingly enough, this nut actually looks more like a rivet. There is nothing on the back side of the bolt. The rear bolt holding the cover on has both a nut and bolt. But the front only has the hex rivet. What gives?
RE: Stripped a hex nut. Now what??
On my StreetBob the front nut is attached to a torx bolt. But my ride came with a chrome belt cover so I'm not sure if the same hardware was used.
If yours has the torx bolt get the right size driver and use vise grips on the nut, then it should come off.
Take a 6 point torx head (best to use one fixed to socket fitting), metric if you have to just slightly bigger then the hex was, line up the points in the corners and tap it in with a hammer(use extension on torx socket when tapping). Drive it in as far as you can, should turn off now!
A little heat on it first will loosen up any loc-tite.
