Cutting stock pipes.
Old 06-08-2006, 11:34 PM
Matrix's Avatar
Matrix
Matrix is offline
Default Cutting stock pipes.
Does anyone know if you can cut the baffles out of the stock pipes on the 2006 Street Bob like I have seen other Harley owners do in the past.
Thanks,
Matrix
Old 06-08-2006, 11:41 PM
rrhemi's Avatar
rrhemi
rrhemi is offline
Default RE: Cutting stock pipes.
Someone on here recommended drilling a half inch hole in them. I think he meant in the center of the pipe.
Gonna take a long drill bit. Said it sounded similar to the SE torque muffs.
Old 06-08-2006, 11:58 PM
Matrix's Avatar
Matrix
Matrix is offline
Ok. I'll have to check into that. I just bought my 06 Dyna Street Bob last Thursday (June 1,2006) and I love it but the stock pipes need help in the sound department.
Thanks,
Matrix
Old 06-09-2006, 01:03 AM
millzog's Avatar
millzog
millzog is offline
Big Kahuna HDF Member
ORIGINAL: Matrix
Thanks,
Matrix
Word of caution , check with your dealer before doing anything like that ...it might void your warranty. If it doesn`t drill away my friend !
Old 06-09-2006, 01:52 AM
phreak's Avatar
phreak
phreak is offline
I'd recommend drilling before cutting. I put 2 1/8" holes in the end caps of the baffles on my old Sporty, and I got more volume. Almost Harley sounding.
The advantage to drilling over cutting them clean out is the phact that you still maintain some back pressure as opposed to making them into straight pipes. Better phor your performance.
But either option should only be a temporary solution. A good set of slipons can be had phairly cheaply. Cycle Shacks phor one are between a buck and a buck phifty, and will give you a hell of a lot better sound then drilled or cored stockers. AND they perform better too.
Old 06-09-2006, 09:26 AM
ss377's Avatar
ss377
ss377 is offline
Check ebay. There are stock mufflers for st bob at reasonable prices. Get a set to play with, keep your originals for warranty purposes.
Old 06-09-2006, 10:23 AM
Mascman's Avatar
Mascman
Mascman is offline
I have a set that I played with.
I took a long screwdriver and chiseled my away around the center baffle. It is just a flat baffle, not like the round type in aftermarkets and some stockers.
It basically made it a straight through design, but the original damping material is still there with the perforated steel holding it in.
They have a decent sound...little louder on idle and then a decent bark when you open it up.
I'd say if you just want something a little better than stock, but not obnoxious, then it will work for you.
Since me and my brother both bought new Dynas and have put slip-ons on them, I will sell the debaffled stockers for $65.00 shipped. I will keep a set of stock ones around just in case!
Can do Paypal or Money order if anyone is interested. I'm in PA.
Old 06-10-2006, 12:35 AM
Matrix's Avatar
Matrix
Matrix is offline
Thanks for the replies. After reading your replies I think that I may have come up with something. I don't plan to ever be without a Harley, therefore I think that I will take some good advice and get a set of slip-ons and hopefully they will fit on the next bike I get years down the road when the time comes. I also would not want to do anything that would void my warranty, that's for sure. What types of slip-on exhaust pipes do you recomend? A guy at the local harley shop gave me a Quote of $600 to add Screaming Eagle slip-ons, Stage 1 intake kit and remapping the fuel system, including labor. ( Is this a reasonable price to have this done)?
Thanks,
Matrix
Old 06-10-2006, 08:45 AM
06dynablack's Avatar
06dynablack
06dynablack is offline
yeah good price figures out to be 85 bux for his labor seeing the pipes list for 229 airfilter kit is 139 i thinkand dwnload is 149 so roughly 85 buxfor labor
Old 06-10-2006, 01:25 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
NEONNIGHT34609 is offline
if u like the looks of the stockers look at these they are cheap and well worth the money .. it does not really pay to play with the stocker pipes
http://www.jpcycles.com/ProductDetai...450-250&cs=All
serverpimp
09-23-2015 02:53 PM
sr556m9
03-29-2015 01:39 AM
Fastfwd
01-02-2009 06:54 PM
MasterRye
08-01-2006 11:55 AM
Garrison1383
03-19-2006 06:39 PM
Quick Reply: Cutting stock pipes.
