I can not get the grip off... i need ideas
Ok... so my F'N grip will not come off... i have tried it all, Heat gun, Screw driver, even channel locks, this sucker will not come off... any ideas? i got in my new gold powder and i want to do my grips and controls but i can not get the grips off! any ideas of something for me to try? I need to use it so i do not want to cut it off... i am thinking that if i heat it and then cool it real fast that may break it loose... no idea
you can even see where i am starting to chew it up smacking it with a screw driver after the block of wood and then PVC failed
Joe, what type of glue did you use?
If glued, have you tried leaning the bike over on the left side, and putting lacquer thinner around the grip to soften it?
Or Acetone/MEK?
Next Q, is the grip polished aluminum, or is it chromed?
Hope theres no electrolysis or you'll be cutting it off
Or Acetone/MEK?
Best bet is pouring a TON of WD40 and rubbing alcohol down in it and hoping for the best...
Received 4,852 Likes
Does your grips have a hole on the end??? Maybe if you heat the outside of the grip and spray some canned air (upside down, so the liquid comes out) in that hole maybe it will cool the bars enough to slid out of the grips...
Probably not possible to powder the grip while still attached to the bar?
