performance Clutch
Old 03-02-2011, 07:02 PM
Turbo ray 44's Avatar
Turbo ray 44
Turbo ray 44 is offline
Default how much?
not sure?
try calling Rivera, ask for John Ventriglla.
Originally Posted by GREENOHAWK69
Approximate cost?
Old 03-02-2011, 10:56 PM
redrubicon2004's Avatar
redrubicon2004
redrubicon2004 is offline
I've been using a BDL lockup with my 107" and have had no problems. It was pretty inexpensive and very easy to install. I tried a Rekluse and had nothing but problems. I tried adjusting it about 6 times according to the instructions. The shop that dyno tuned the bike also screwed with it for a little while and it kept slipping.
http://www.phatperformanceparts.com/..._p/bpp-500.htm
Old 03-03-2011, 05:56 PM
Los11's Avatar
Los11
Los11 is offline
Originally Posted by sharkey
Thanks for the reply; I'll put auto primary tensioner on the list.
Gonna take the top end off and do a detailed inspection for wear...re-ring or overbore as required, freshen up heads as required...see what we find.
If the crank looks good; then she's back together, hopefully for another couple of years of summer road fun...if the crank needs attention; then probably go back together as a 113.
Have you done the SE Compensator? Thats something I would add. I am doing a 107 build with Hillside Stg 4 heads probably gonna see around 120+ TQ I just got the Barnett Scorpian Clutch I know I probably didnt need it but its a real nice clutch. You can probably just get Barnetts Clutch Pak and AIM VPC like other have suggested but I wanted a whole new clutch....
Old 03-03-2011, 06:59 PM
bigdaddy33's Avatar
bigdaddy33
bigdaddy33 is offline
You did not go wrong with the Barnett Scorpion. It's an awesome clutch and for me has performed flawlessly.
beammeup
The Dyno Room
05-10-2016 08:43 AM
Hunter424
03-18-2016 09:07 PM
fxstc1999
07-01-2011 04:18 AM
Peekon
01-05-2010 05:12 AM
wiseguyups
08-30-2009 07:32 AM
Quick Reply: performance Clutch
