Weld baffles in Chrome exhaust, ruin chrome plating
Old 08-24-2009, 09:35 AM
agreif's Avatar
agreif
agreif is offline
Default Weld baffles in Chrome exhaust, ruin chrome plating
Guys, when you re-weld in baffles into a chrome exhaust, does it ruin the chrome plating or can it get TIG/MIGed in without a problem?
Thanks,
Andrew
Old 08-24-2009, 10:09 AM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
Welding on chrome will most likely ruin it. Why not just bolt them in?
Old 08-24-2009, 10:27 AM
moguy's Avatar
moguy
moguy is offline
+1 on bolting in!
Old 08-24-2009, 10:42 AM
gibby122's Avatar
gibby122
gibby122 is offline
Im a pre-schooler when it comes to welding experience at best, but a proper weld will more than likely discolor the chrome at best, probably bouble. My old V&H had bolt in baffles, which I prefered, you could take them out, change them out if you wanted to, Id go with the others and vote on bolt. You can find baffles that bolt in, all you have to do is drill a small hole, normally on the the under or back side of the pipe. small allen head bolt and bam, bobs your uncle.
Old 08-24-2009, 12:13 PM
joemacro65's Avatar
joemacro65
joemacro65 is offline
+1 What everyone else said. Unless Im missing something, it would be a bad idea to weld in you baffles
Old 08-24-2009, 12:22 PM
fixxr's Avatar
fixxr
fixxr is offline
If you have removable chrome covers take them off weld and put them back on.If they don't come off drill a hole on the backside and bolt them on.EZ
Old 08-24-2009, 12:24 PM
883 IRON's Avatar
883 IRON
883 IRON is offline
Anyone try riveting?
Old 08-24-2009, 02:40 PM
agreif's Avatar
agreif
agreif is offline
ok, allen head and an lock nut and washer it is then.
nevil
10-06-2010 09:41 AM
Heritagesoft
12-05-2009 04:05 PM
bmxatv
07-21-2009 10:22 AM
creekhed1
11-10-2008 07:42 AM
ssfirefighter
Detailing
08-18-2006 10:10 PM
Quick Reply: Weld baffles in Chrome exhaust, ruin chrome plating
