can i remove the bracket on the left side of the bike ...
Old 08-18-2009 | 06:23 PM
Bobbed Out's Avatar
Bobbed Out
Question can i remove the bracket on the left side of the bike ...
that mounts to the top of the jugs and holds the plug wires and has the horn mount? it looks like it mounts to the frame about the middle of the bike but doesn't seem necessary. after i moved my horn i have this ugly bracket there serving no purpose ..
i know a lot of you have relocated horns .. what's the deal with this bracket?
Old 08-18-2009 | 06:48 PM
Bobbed Out's Avatar
Bobbed Out
surely someone must know what to do about this ugly *** bracket in the way
Old 08-18-2009 | 06:55 PM
WS6 Formula's Avatar
WS6 Formula
No, look at the very top of the bracket, it is also an engine mount.
Old 08-18-2009 | 07:45 PM
Bobbed Out's Avatar
Bobbed Out
yeah so how do you get rid of that bolt that the horn mounts to? just cut it?
Old 08-18-2009 | 07:47 PM
Mascman's Avatar
Mascman
Sure..take it off, you don't need it.
Seriously, you could take it off and grind the tab off for the horn mount...hit it with paint and you're good to go.
Old 08-18-2009 | 08:05 PM
WS6 Formula
Put two nuts on the stud and jam them together, then use a wrench to unscrew the rubber mount. The rubber mount will feel like it is going to shear off just before it unscrews. Be careful that you don't hit the tank with the wrench when it breaks loose.
After I took off the rubber mount, I used a bolt and some wire to support the front ignition wire.
Old 08-19-2009 | 07:55 AM
Rickr01's Avatar
Rickr01
You've made some real nice custom modifications to that bike. I've noticed many subtle changes done very tastefully. Nice job!
djkolp
02-17-2018 12:29 PM
lhgdale
2014-2023 Touring Models
15
12-26-2014 03:43 PM
ssgunny
10-31-2014 04:23 PM
Redder
02-19-2012 12:38 PM
watercop
12-24-2011 01:27 PM
Quick Reply: can i remove the bracket on the left side of the bike ...
