Shock Adjustments ??
Old 08-19-2009 | 01:40 PM
Sammi's Avatar
Sammi
Used a strap wrench on my '06 Low Rider and it worked fine. Would have been easier if I had a jack.
On mine you can see the load setting on the bottom of the shock looking at it from the rear of the bike.
There is band with numbers and an arrow indicating the current setting.
Sammi
Old 08-19-2009 | 01:42 PM
2007fxdc's Avatar
2007fxdc
Originally Posted by antman27
I am courious where my is sat at now -I think it feels stiff and that may make sence the guy that owned the bike b4 me was a BIG guy so I am not sure if any adjustments were made for him
You can look up under the shocks and see where it is now. I think the stock shocks come with 5 settings, or maybe it's 4, but I think it's 5. Looking from underneat the shocks you see, around the shaft of the shock, something that sort of looks like a side view of a circular staircase. Each step is a setting. If you don't see any, it's probably because it's clicked to the max preload. If you do see any steps, count how many you see, add 1, and that's what yours is set on right now.
Old 08-24-2009 | 09:09 AM
antman27's Avatar
antman27
Just as I thought they were on #4 the stiffest setting
I went 4 clicks the other way and went out for a ride -I never bottomed out and bike felt a bit softer
ghawthorn
07-07-2012 06:29 PM
BB06FLHX
09-13-2007 03:12 PM
thomasf59
09-07-2007 12:59 PM
DustMan
06-01-2007 01:08 PM
supermario
02-20-2007 06:01 PM
Quick Reply: Shock Adjustments ??
