Shock Adjustments ??
I noticed the part number is the same for all models so they may not screw up this time...
Bill
The shock spanners are all basically the same,mine is a PS one..I have standard SB shocks and to adjust them harder you turn them clockwise if your looking at the bike from the rear.I carry a passenger most of the time and have them set on setting 4..think theres 5 settings.If you use the spanner carefully it won't mark the chrome but if your worried just put a rag between the spanner and the shock.
Regards sumpnut
Regards sumpnut
I was worried about the same thing. Just be careful with it and it won't hurt anything. I used one on my old stock shocks and on my new progressives and never got a scratch.
Regards sumpnut
Regards sumpnut
Just did mine the other night. As you face the bike, turn the collar on the bottom of the shock from right to left, to increase the preload. Used a "C" shaped spanner meant to adjust the shocks on a Sportster, and it worked fine. Looks like it came through from the factory on the lowest preload setting.
