Turn signal and ghost brackets (D/U warning)
There was a docking port that was supposed to go on that bolt that mad there be too much slack. I was able to build it up inside with washers but if I were to bottom out I felt it was too close to the tire for safety when I did that....I could have dremeled off about 1/3 inch but the threading may not have had enough to give good grip so I just went with the other "makeshift" solution.
My wires for the rear turns run into the tail light and are plugged in there. No need to cut any wires to relocate the signals.
Are the signals now mounted in the plastic behind the rear fender? Think that will hold up under the constant vibration they're going to be dealing with? I looked at the ghost brackets and thought I could make them work even with my rear turns in the rear holes on the struts. But thats for next season I guess.
