I want to remove my front turn signals .. need advice
Old 08-14-2009, 02:16 PM
Bobbed Out's Avatar
Bobbed Out
Bobbed Out is offline
Question I want to remove my front turn signals .. need advice
i've read and read and read some more this afternoon about the possible complications of removing my signals. i need to get some clarification if possible.
i have an 09 SB with the factory installed security system. will this in fact mess anything up?
aside from that .. what's the easiest way to pull them out? i'm thinking trace them back to underneath the seat and then cut them at the clip and pull them out from up at the bars.
thanks for the help i need it hah!
Old 08-14-2009, 02:24 PM
Bobbed Out's Avatar
Bobbed Out
i just spoke with the local dealer who told me that it won't conflict with the alarm system but that my rear signals may stop working completely ..
lol i'm so confused
Old 08-14-2009, 02:25 PM
reesestewww's Avatar
reesestewww
reesestewww is offline
Old 08-14-2009, 02:26 PM
formike56's Avatar
formike56
formike56 is offline
I did it to my 07 WG. Unpluged them from under the tank. No problems.
Old 08-14-2009, 02:29 PM
bberck's Avatar
bberck
bberck is offline
Unplug them and see what happens, worse case I think you may need a load equalizer.
Under the plastic cover under the tank you will find the plugs.
Old 08-14-2009, 02:34 PM
DGDyna's Avatar
DGDyna
DGDyna is offline
PM stell55chevy. He says he don't need no stinking turn signals!
Old 08-14-2009, 02:54 PM
stell55chevy's Avatar
stell55chevy
stell55chevy is offline
haha! that's right! just unplug and run down the road! do the horn to while u are at it.
seriously, i unhooked just under tank and have been like that for at least a year.
Old 08-14-2009, 03:52 PM
Bobbed Out's Avatar
Bobbed Out
do i have to take the tank off to do this? i can't find any friggin clips under there at all
anyone have a picture of where they're at?
Old 08-14-2009, 04:00 PM
bberck's Avatar
bberck
bberck is offline
Helps to lift the tank up some but dont have to remove it.
In the middle of the frame under the tank is a plastic panel. Just pop it out and all the wiring harness's are shoved up there.
Here is a picture Mud posted
Old 08-14-2009, 04:02 PM
Bobbed Out's Avatar
Bobbed Out
ok so can i take off just the front or rear mount? or do they both have to come off? ..
and what has everyone else done? fished the wiring out or just cut the wiring at the controls?
Quick Reply: I want to remove my front turn signals .. need advice
