Thunderheader Installation Instructions
Old 08-08-2009, 12:41 AM
bucket13's Avatar
bucket13
bucket13 is offline
Thank you all for you words of encouragement and advice. I read many of the installation threads and i fear that this will be a struggle. Not sure when I will attempt to install the pipes, but i will keep everyone informed of my progress.
Old 08-10-2009, 07:59 PM
lhcstreetbob's Avatar
lhcstreetbob
lhcstreetbob is offline
Default thunderheader
hey man not sure if you decided to tackle the project yet? i thought of something else that will probably help you during install ...take off the battery box battery and all it makes it alot easier .. good luck
Old 08-10-2009, 10:29 PM
tweakin's Avatar
tweakin
tweakin is offline
An easy way to instal the 2-1 is to hold the pipe almost upside down and sweep the pipe in (both sides of the header at the same time) starting at the narrow part of the cylinders then up to the exhaust ports at the same time. Once the pie is in place put the exhaust flanges on and lightly put the 4 exhaust bolts on to secure the pipe. The put the rear mounting bolts on lightly to support the pipe a little more. Once this is done tighten the exhaust flange bolt snug then the rear mounting bracket.
My pipe went on real smooth without a hitch this way.
Old 08-10-2009, 10:56 PM
lhcstreetbob
yeah that sounds like it would work i had never done it before and it whipped my *** for a couple of days until i finally figured it out ...i could never get all 4 flange nuts on at the same time.
Old 08-11-2009, 04:34 AM
bucket13's Avatar
bucket13
bucket13 is offline
Thanks fellas.....still trying to find time to do this. I will keep everyone up to date on the results.
Old 02-10-2010, 05:10 PM
DMV11982's Avatar
DMV11982
DMV11982 is offline
Wow..getting ready to do mine and didnt think it was this tough!! Good thing I have a friend that is Harley Davidson inclined!!
Old 02-10-2010, 05:48 PM
lhcstreetbob
yours should go on pretty easy its proabably stretched out after bieng on adrians bike... mine goes on alot easier now it was stiff as hell the first time..
Old 02-10-2010, 05:51 PM
HOGRIDA_06's Avatar
HOGRIDA_06
HOGRIDA_06 is offline
I just put on mine, it's from an older Softail. It fit right up no problem. I just took off the mid peg and brought it up from the bottom. The only thing I don't like is how low it hangs. That sucker is going to drag bad. I'm gonna have to do some cutting and welding to get it right.
Old 02-10-2010, 07:11 PM
DMV11982's Avatar
DMV11982
DMV11982 is offline
Hog, lets see pics, did u wrap em up?? Love the short shots u had!!!
Old 02-10-2010, 07:17 PM
HOGRIDA_06's Avatar
HOGRIDA_06
I left my camera at work but I'll throw up a pic in a day or so. I plan on wrap but not until I get it hanging right and get the O2 bungs in.
Quick Reply: Thunderheader Installation Instructions
