2nd time inner primary bearing
My inner primary bearing went again for the second time. It went last year ( under warrenty) at 13,000 miles. Took a trip last week to Cooperstown MLB Hall of fame, when I was pulling off my exit on the GSP i could hear the whine again. 18000 miles and the dealer says they wont cover it. Have to call the MOCO today so I can hear them say they wont cover it either.
Inner Primary Bearing
I have an '06 Street Bob and my first Inner Primary Bearing went out some where around 8,000 miles. My second one went at just over 18,000 miles. Luckly my bike is still under extended warranty. Here is what the H-D Shop did when they changed mine out the second time: They also put in the latest up graded automatic primary chain tensioner. All I can say at this time is... The up dated tensioner has taken the whine out of the primary chain. Therefore I'm sure it is reducing the pressure on the inner primary bearing and should extend its life. I would highly recommend going to the latest up dated Primary chain tensioner and I believe this may cure your problem with the bearing.
Read my IPB threads ! ! ! HD SHOULD cover it AND give you the "Full Monty Fix". You've got a problem-child '06 like so many of us. I got new bearing, tranny case, IPCase, etc., and HD paid the bill this last May, 2nd failure. Educate yourself on this issue! Have a copy of the pink letter in front of you when you call Milwaukee. Be pleasant, don't yell, threaten or cuss. All the info you should need is in my "Finally. Good News..." thread from 5/6/09; read it before you do anything else. Also read any links in it. Make sure you have 'em closely inspect your rotor while they're in there (the other '06 issue). Good luck; PM me if you need any more info/ammo.
IPB on wife's 06 Street Bob went at around 13k, still under warranty, local dealer (not selling dealer) took care of it no problem. 2 weeks ago (2 years + out of warranty) same dealer replaced bearing again no questions, we brought in the copy of our letter received at time of purchase (Aug 05). The dealer did not do any of the upgrade type things (new cases etc) but at least they went to bat for us with the factory...I've read and re-read the letter; all I can say is the factory best not ever give us **** about this issue....I got a lawyer who's practically drooling over this one. BTW, her stator went 10 days out of warranty (2 years ago) while we were down in Tn for the national rally....now we keep hearing this is a known and ongoing issue...perhaps I need to investigate further...
Troll;
When/if it goes again, call Customer Service in Milwaukee instead of going to your [helpful] dealer for another bearing/race. This is an alignment issue, and unless they get the [non-dowelled] IPCase installed perfect, you'll prob'ly keep eating IPB's. You should get the Full Monty Fix next time; seems to be the way HD is handling the issue. First fail, you only get a new bearing/race; 2nd time, you get the goods.
