I have the 5 3/4 Cobra II on my 04 lowrider. Do you have an install question or looking to see a pic? I would think they both install pretty similar.
I have an install question, I must drill a hole in the lower tree to mount it. My lower tree has a channel in it so the hole must be drilled in the middle of it, the offset that they provided seams like it is going to be too short. What did you do?
Jay
I drilled the hole in the middle of the channel, tapped it and put a bolt with locktite on it in so I didn't have a nut on the bottom sticking out.
I also had to buy a headlight mount for a springer similar to the one below to get the headlight out far enough from the frame of the bike. The one that came with it was just to close.
All in all it took me 3 or 4 mounts to get it right. I have them in a box somewhere. Since your headlight is the smaller one, maybe one of those will work for you. If you want I can take pics later and email them to you.
The one on the left is the one that came with my headlight. The one on the right was purchased and ended up just a little bit to small. I needed another 1/8 inch.
