Cams.. 211s
http://www.bigboyzcycles.com/tccams.htm If I would have went with SE it would have been the 204's, the 211's powerband is in the higher RPM range.
Just curious...have ya checked out other brands grinds, or is the dealer installing them & saying they won't install anything but SE? Either way SE grinds work good, but others are better. If it doesn't really matter to you then just get the cams that will work in the rpm range that you like!
Received 4,767 Likes
This is right from a SE performance catalog...The 211 cam is best suited to added compression, and offers good mid- to top-end power. A good match for the "HTCC heads or Twin Cam 88 performance heads. 204's produce peak power around 5800 rpm. The 251 cam is a high lift, torque cam designed to be used for larger disp. engines where mid range power is desired. Granted this is from an '04 catalog but I hope the info helps.
I think before you ask a bunch of people how much they like a particular cam, you need to define how you're going to be using it first. Everyone here is going to tell you that what they use is best. Whats best for them isnt necessarily whats best for you if you have no idea what you want from the beginning.
Do you have any idea what you want from your motor, or what you riding style is?
My setup now is Stage 1 SE air, V&H BSS, Powercommander V...
It seems I just need to do the head work an the cams.. an be done with it..
http://www.harley-davidson.com/en_US...SE_032_067.pdf They explain matching cams to desired RPM range, I'm happy with my 37's.
