load equilizers
Old 08-04-2009 | 06:11 AM
stbobshadow's Avatar
stbobshadow
Default load equilizers
Do the load equilizers get hot to the touch.
Old 08-04-2009 | 08:30 AM
bberck's Avatar
bberck
Most will and you need to stay away from those.
I have a Badlands lll and it doesnt get hot. I bought the ones with the plugs (they have one that you splice in as well) on it so took longer to take the seat off than it did to hook it up.
Biketronics also has one that doesnt get hot to give you a second choice.
Old 08-04-2009 | 09:00 AM
AmericanIron's Avatar
AmericanIron
I have the Badlands and it works great, plug and play and cool to the touch.
Old 08-04-2009 | 10:05 AM
jluvs2ride's Avatar
jluvs2ride
From: Back in the Good Ole USA. South Carolina to be exact.
I have the badlands, cool reliable easy install and they are great folks to deal with.
Old 08-06-2009 | 11:42 PM
yoseppi's Avatar
yoseppi
Is there a recommended retailer for the Badlands unit, or is fleabay the way to go?
Old 08-07-2009 | 07:10 AM
bberck's Avatar
bberck
Got mine off ebay
Old 08-07-2009 | 07:53 AM
AmericanIron
I called Badlands directly...talked to a guy there he hooked me up with the equalizer i needed and the LEDs with free shipping and 10% off. Parts arrived 2 days later. Cant beat that.
Old 08-07-2009 | 09:05 AM
doublenaughtspy's Avatar
doublenaughtspy
ok - I'll bite - what does a load equalizer do?
Old 08-07-2009 | 09:36 AM
bberck's Avatar
bberck
LED bulbs don't draw as much current so they can not work properly without a equalizer.
They may blink fast or mess with the security system.
Old 08-07-2009 | 10:04 AM
'09fxdb's Avatar
'09fxdb
What if I only put leds on the rear...if I plug the load eq. into the wiring system, does it know where the leds are and will it have anything to do with the the front bulbs?
Bill
