Want to put wide glide trees on. What extra?
Looking to put a wider front end on my FXDX. Can't stand the sporty front end.
Other than triple trees what other extras will i need to do this i.e. spacers for the fender, etc. Any one that has done this, that can lead me in right direction on this would be a great help.
Thanks
Thanks
I went from the 39mm front to a wide glide front. You will need a full front end from a wideglide. Probably a new wheel too. Your dealer can give you a blow up of the wide glide front end with all the part #'s. From there I would suggest zanotti's for the parts. Zanotti's save me about 300 bucks off the local dealer prices. Also you will need a bottom mount headlight as well. You can also go to a mid glide 06+ front as well with the 49mm fork tubes. Another thing you will want is a 2" lowering kit for the front springs. The wide glide fork tubes are about 2" longer than the 39mm front end.
i did wide glide trees with 49mm street bob forks. no lowering needed. wish I could give you part numbers but i got everything off ebay and other forum members.
it's not hard at all. you just need all the parts. like others have said, start with a blow-up diagram and start collecting parts.
lilsahara450r
03-30-2010 10:30 PM
