Sissy bar upright and pad
Ok think I am going to get some detachable stuff to put on the bike.
Got the mounting hardware and side plates that I need to do it picked out but the sissy bars are hard to tell from pics of them unmounted.
Basically it will never be on the bike unless it has luggage on it so I figure I need one a little taller for a good size bag. Wife has never ridden but would like it to be a good height for her just incase.
Also which of the 2 racks is better for a larger bag
So which Sissybar/Pad/rack would you recommend.
bberk I use the Low Sissy Bar with the Low Smooth Baclrest and a Sport Luggage Rack on a detatchable set up. It has worked well for me when Mama rides on the back. The wife says the backrest is not bad and the rack supports whatever we load up in the bag. Detatchable is definitely the way to go just because you can put on or take off in less than a minute.
HD has 3 or 4 different heights, and mine came with the medium low, which I ended up shelving in favor of the short one like archergodwin has due to the fact just a couple inches made a difference for my wifes comfort.
She is about 5' 5", goes about a buck thirty, and the tad taller one sat high enough in her back to make her set a little too forward to keep me from gettin any for a couple of days............
It threw me due to the fact she spent 12 hours on one last winter in complete comfort, but as I began to dig I discovered they had a few variances that "looked" the same from a distance.
I gave the dealer the 100 dollar bill, and she has been comfy ever since.
Only if you intend to put bags on. The detachable hardware does require a relocation kit, which mounts the turn signals in the rear fender strut mounting hole. But since I wanted to use detachable bags also (Easy Brackets), I needed to move them to the fender.
That is HDs cheap turn signal bar... I'm planning to redo the tail light/turn signal setup... just not sure to what yet... haven't seen anything really grab me.
