How hard is it to install a new tank/hardware on fat bob?
Hey everyone,
I have a new set of tins coming with different paint in a few weeks. I am going to need to move the fuel lines/fuel gauge/ etc to the new tank. I was wondering how difficult it will be to do myself or if I will end up needing to get the local indy to do it? I didn't know if there is a fuel pump in the tank to contend with or not????? Any advice would be appreciated. I think I can handle the fenders without issue but the tank could be a little bit of a challenge. Thanks.
Hey everyone,
lee, it's not too bad, take your time, it's all in your Service Manual,
and you can have a look at post #3, (fuel tank disassembly), here.....
No way on the tire removal. I took mine off the other day to put on a tri bar tail light. Real simple. Remove seat and ground from battery. Two studs on each side off fender need to come off, they screw into a bracket that will fall out when you get both bolts out off one side-- an extra hand will prevent scratches. Remove taillight lens and unplug signal wires. Remove stud inside fender that holds signal light on and pull wire through. You will need to locate and unplug connector for the rear lights. Under the seat. Mike.
