Rear end done till winter
Started my rear end project about a month ago and its finally all done for now.
Still plan to do some fender work and lose the taillight but decided to hold off till winter because I want to do some other paint work at the same time.
Here is what I did.
Progressive 812 shocks
SE 180
Chrome Pulley cover
Side Mount plate with LED frame
LED turn signals
Personal Plate
Installed a run/brake/turn module but it quit working after a day
Couple small things
Painted the reflectors in the turn signals black for a better look. Did the front as well and ordered LED bulbs for the front.
The shocks exposed the top shock mounts alot so I painted them black.
before
Here is what I did.
SE 180
Chrome Pulley cover
LED turn signals
Personal Plate
Couple small things
before
Mines a HD one as well. One turn signal stopped working as run/brake but still worked as a blinker. I messed with it some and got it to come back on but it was very dim. Going to check all the connections and see if its just a bad connection.
I believe the horizontal mounts are legal in WI but not the vertical. I have one but haven't put it on yet.
