Where to put my cane?
I got a fix for that that works just fine for me. I have a leather shoe lace like used on hunting boots. I slipped it behind the fender hanger. I lay my cain with the hook end of the top of the left shock mount and let the other end rest on the turn signal. I then tie the rawhide lace around the mid section fo the cain and tie in a conventioanal bow ! Works like a champ. I thought of a dozen Rube Goldbergs but the leather lace has not loosend on me yet and is a low tech answer to the problem.
PS, if you mount the cain on the left side of the bike you can occasionally reach down there with the left hand to see if it's still snugged up while you're riding along.
a sheath made for it that would strap to your bike somewhere...
__________________
It would be no big deal to make one of those. There is also a thing called a ball bungie that can be fastened and unfastened pretty fast and they're cheap. http://www.tarpsonline.com/limage.as...c=Ball+Bungies
__________________
not embarrassed
I use a fold-up cane and carry it in the tool bag. When I get where I'm going, I put on a wig and put it in my purse. That way I'm not embarrassed to be using an old lady's cane.
Cane Holder
A quick fix would be to go to home depot or lowes and get a package of rubber grommets and find the correct size to fit around your cane. If you use 2 of them you can velcro to them to you handlebars and they will not slip on the rubber. Home Depot sells a package of assorted sizes with 2 of each size in the electrical/conduit section. Good luck.
Rusty Springs (05-01-2023)
https://www.amazon.com/hz/wishlist/ls/29JFEF0M5ZPZW?ref_=wl_share
