Installing Motherwell rack question
Just got a 7" matte black Motherwell solo rack.
No instructions. Now, I know it's fairly obvious how to install it, but:
-- the front lip, does it go under or over the seat's lip? Does it even matter? I put it over the seat, since with the seat lip on top the seat wiggled a bit.
-- it came with a screw, a metal washer, a plastic washer, and a square piece of peel-and-stick foam with a hole in it. I put the foam under the rear mounting hole of the rack, which seems right. I also put the metal washer above the rack, right under the screw head. What's the plastic washer for?
Thanks.
Thanks.
