New member In need of help!
I have a 1996 fxdl with a major starting problem. Everything in the starting system has been replaced over the last year. I will get it back from the shop and it will start fine for a little bit but sooner or later the ring gears strip and no start. I have had 3 mechs look at it and the problem is still there. my local Harley dealer looked at me like I was nuts and told me basically they could start guessing at the problem but they didn't even know where to start. Now my shop thinks its in the ignition sysm. but my faith in him is shot. anyone ever have a problem like this before? any info will help. Please help me stay on my Harley
Received 4,807 Likes
How long have you had the bike and is this a new problem or did it come with the purchase? Did you buy it from the original owner? If not did you buy it from the person that did the cam, pipes etc..? If not it may be possible there has been more work performed internally (more compression). When you say hard starting when it's cold do you mean it cranks a lot before it starts or does it struggle to crank over? Sorry for all the questions but it may help solve your problem.
You ain't jerking around on the fuel are you? If the bike was designed to be run on high octane fuel you should run it on that. The "flash point" of fuels is different. I used to put in the expensive gas in my company car every once and a while to supposedly clean out the jets. The car was very hard to start with high octane fuel in a car designed to run on low octane.
Daleckio
03-31-2011 12:26 AM
