FXDX Shocks
FXDX Shocks
I recently bought an 05 FXDX, and just finished the Stage 1, bike runs great, then I noticed the left rear shock is leaking. Just wondering if anyone else has had this problem.
The OEM shocks are $323 ea , OUCH!, and I don't know if it is okay to just replace the bad one.
I see used FXDX shocks on Ebay, could be okay but you never know and these shocks are not rebuildable.
The WORKS shocks look like they may be good, about the same price as the OEM HD and they are rebuildable.
There's not to many options for an FXDX. The ride height on that model is higher than most, also the suspension in adjustable. I would stick with OEM if you like the ride and the height. If not the three mentioned above are all quality products. Just remember if you change the ride height in the rear it's going to effect the whole bike. I think Works makes a setup for the front and rear. It will lower the whole bike and tighten it up a bit.
