Changing to Gear Drive?
I got 32000 miles on my bike now and I have been told I should check my cam bearings, The cam chain tensioner and the cam chain. So thinking about this and doing some research maybe I should just chance over to the gear drive.
My question is if I go this route can I do it without changing my cams?
If I need to change the cams which cams should I go with that don't require any other motor work? I like torque more then HP...
Here are the cams I was thinking about, what you think?
Part number 288121G
Or maybe a kit that comes with everything needed?
Thanks for any help guys!!
Naz
Part number 288121G
Naz
Received 4,802 Likes
Never heard of this, could you elaborate? Does someone make a kit? I know with mine there is no way to go full gear drive because the inner sprockets are part of the cams.
I remember visiting revolutionperformance.com and they will true and weld your crank for about $100. That way you will have no more than .001" runout. If you have more than that the gear drive won't work. Too much shifting of the crank. Let me clarify on the revperformance price....that's you sending them your crank.
That is definitely a winter project. You could do all your upgrades then.
