Forward controls on Low Rider.
The question about the shifter shaft. Yes, and the inner primary case to remove it completely then find a plug to fill the hole. To remove the inner case the clutch/starter ring gear and primary chain comes out. I used the HD kit on my L/R part no. 49080-03 this kit has a little cover that will fit on the shaft stub. If you remove the shifter shaft get an inspection cover for the 03 Wide Glide model.
To clarify, you typically have to open the primary and remove components if you install the HD forwards kit. The Kuryakyn forwards kit comes with a chrome cover to install over the shaft spline and is overall very easy to install. I believe the HD kit can be installed the same way if you can get the right parts.
The HD kit has everything needed for this job. It's the same on the FXDL of the same year bike, an 03. The 99 thru 05 Dyna's are basically the same bike and primaries. The 06's and newer have slightly different primaries and yes I think you can remove the shaft on those bikes. When the shaft is removed on the 07's don't you have to seal the hole in the inner case? I was only relating my experience with that generation of Dyna's.
I installed the HD forward controls on my 07 FXDC using kit no. 49080-06A. For your bike you would use kit no. 49080-03A. The way I understand it, the kit for your year bike has brackets in it that are used to hold the existing shifter shaft in place, so you don't have to remove it. When I did mine I left the shifter shaft in and just tucked the part that the shift linkage attached to, behind a bolt on the engine. It stays in place and doesn't rattle at all. Take a look at the attached pic and it'll show what I'm talking about. Just saying it's another option for you.
