Fork Reflector Removal?
Old 07-04-2009, 10:52 AM
Jonn2002's Avatar
Jonn2002
Jonn2002 is offline
Default Fork Reflector Removal?
What is the best way to take the reflectors off my forks without messing up the black paint?
Old 07-04-2009, 10:54 AM
OhioSkully's Avatar
OhioSkully
OhioSkully is offline
Most guys use a hair dryer to get the reflector a little warm and it will pull right off. You can also get pcs of fishing line behind it to get it started and help pull
Then use some go gone to clean off any sticky stuff
Old 07-04-2009, 10:57 AM
K9pusher's Avatar
K9pusher
K9pusher is offline
I used a heat gun and then pulled it off. Then I used goo gone to clean up the residual glue.
Old 07-04-2009, 10:58 AM
JaronB's Avatar
JaronB
JaronB is offline
Use a blow dryer to heat it up. Pull it off, you'll have to give it a good pull. Use an old ID card to get leverage under it. You are going to have residual once you pull it off. Heat that up some more and just rub it off in one direction and when you have all the thick stuff off some have used goo gone, or WD40. Make sure you wash your bike afterwards. I just rubbed everything off with my thumb and waxed it up!!
Old 07-05-2009, 07:56 AM
SC-Longhair's Avatar
SC-Longhair
SC-Longhair is offline
Hydrochloric acid. It'll eat anything off.
Old 07-05-2009, 08:21 AM
maddghost's Avatar
maddghost
maddghost is offline
Yes and clean up with liquid nitrogen to cool things off a little!
I'm gonna do mine right now! I'll let you know how it went if i still have fingers to type with!
Old 07-05-2009, 08:34 AM
Ratster's Avatar
Ratster
Ratster is offline
DOH!
Old 07-05-2009, 09:54 AM
guff's Avatar
guff
guff is offline
Before getting out the fishing line, dental floss, goo gone, etc. Try prying the reflector off with your hands. I was able to get both of mine off very cleanly using only my hands. I guess the bike was new enough the adhesive hadn't cured to the paint very well. I only used soap and water to clean up. Maybe you'll get lucky and not have to deal with the goo left behind. Wait, that didn't sound right at all!
Old 07-05-2009, 12:24 PM
Poisond 08 Fatbob's Avatar
Poisond 08 Fatbob
Poisond 08 Fatbob is offline
I used a scheringe to keep squirting goo gone behind the reflector. After it was soaked enough I used a heat gun to warm it up then pulled it away and then cleaned up the paint. There is a reflection in this picture. The paint isn't damaged.
Good luck,
Tim
Old 07-05-2009, 01:42 PM
ZeroFiveFour's Avatar
ZeroFiveFour
ZeroFiveFour is offline
1: Use Blow dryer to heat area under reflector for a few minutes.
2: Give a little pull with your hands, shoud pop or peel right off.
3:Clean up by rolling the residule small clumps of adhesive with your little old fingers.
4: Use a nice cleaning product to get it ..Ohh so shiny..ei: Harley gloss.
OR...leave em on so you get noticed by the little blue haired old ladies and the soccer mom's on cell phones...
...nah they wouldnt see you anyway =) LMAO
Cheers,
Tom
Quick Reply: Fork Reflector Removal?
