Front wheel spacers on a 06 FXDC
Today while trying to solve the mystery of why my front wheel seems to point to the right (I bought this bike used, previous owner went down twice with it) I loosed the pinch bolts at the triples, at the axle, loosened the axle and tightened back everything. same result.
I did notice however the throttle side wheel spacers is thinner than the clutch side.
is that correct? i had a tyre change recently and wondered if that was correct.
i did try swapping both, and found the tyre too much offset to the clutch side (the edge of the tyre was out of the fender coverage)
+1 wheel should not point to the right even if the spacers were in wrong it would just not be centered. If the wheel is not straight on axis something is bent
i really regret viewing the bike during the night and buying it without seeing it under sunlight. Only after i took over it, then i discovered pipes were rashed on the underside, triples, crashbars.
They said because these are cast alu items, they either break or stay undamaged (upon impact). They don't bend. Is that true?
Thanks, Jay. But I really wouldn't start thinking of chrome till I've at least gotten the bike pointing straight. Appreciate the pointer though..
you don't mention how your bike rides. what is the ride like?
I'd think that if it was messed up - you would immediately notice it in the ride quality?
are you sure the wheel is actually pointing to the right, or is the fender bent, giving the illusion that the wheel is off?
