Help, Barely made it home . Bike sputtering.
Old 06-28-2009, 06:00 PM
rambobob's Avatar
rambobob
rambobob is offline
Default Help, Barely made it home . Bike sputtering.
Just walked in the door. 3 shots of anejo teq and I am feeling better. Bike is sputtering and will not run under load. Checked spark plugs, all fuses, new gas, battery terminal was a little loose , fixed that. riding 250 miles to get home. Engine light comes on and off. Everything seems fine but runs like sh-----t. Any Ideas. Guess its going to the stealer soon. could not find any loose connections . Any ideas , Thanks.
Old 06-28-2009, 06:02 PM
rambobob's Avatar
rambobob
rambobob is offline
Almost forgot, Thanks to all who offered help while on the rode. I learned a hard lesson today. Computer bikes s-----ck sometimes.
Old 06-28-2009, 06:10 PM
archergodwin's Avatar
archergodwin
archergodwin is offline
Find out what diagnostic codes your ECM is throwing. With the engine light going on and off, sure bet you've got some codes you can look up.
Old 06-28-2009, 06:33 PM
rambobob's Avatar
rambobob
rambobob is offline
How do you do that. Will my sert tell me if I hook it up. My computer died.
Old 06-28-2009, 07:05 PM
archergodwin
Yes you should be able to see your codes when you hook up your SERT.... except if your computer died...
There is a way to pull them out using the blinkers as a 'morse code' type system.... I'll see if I can find the thread again...
Here it is:
https://www.hdforums.com/forum/3988078-post4.html
Old 06-28-2009, 07:46 PM
rambobob's Avatar
rambobob
rambobob is offline
Here it is:
Thanks for the help. code ---- d1A9 did not see that on list . first time doing this. Not on list.
Old 06-28-2009, 07:56 PM
UK Dave's Avatar
UK Dave
UK Dave is offline
It actually reads diag (not da19) which usually means you held the button down too long, try it again and see what happens.
Old 06-28-2009, 08:02 PM
archergodwin
Can you verify that code is what you get, 2 or 3 times?
Would help, just to make sure.... 'cause that code is not in my 08 electrical diagnostics manual...
NOTE:
When you see the D1A9, push the button again. record the number, push again and record the next number, if there is one.
Old 06-28-2009, 08:06 PM
UK Dave's Avatar
UK Dave
UK Dave is offline
Look at how to do the procedure again, what you are seeing is the word "diag" listed in step 3.
Old 06-28-2009, 08:07 PM
rambobob's Avatar
rambobob
rambobob is offline
Thank You. Did it again. Code p0263
Quick Reply: Help, Barely made it home . Bike sputtering.
