Help, Barely made it home . Bike sputtering.
Old 06-28-2009, 10:57 PM
NoLongerAmember's Avatar
NoLongerAmember
NoLongerAmember is offline
Originally Posted by WS6 Formula
Injector wires are know for being installed in the factory with no service loop. So sometimes the wires are pulled when the rubber mounted engine is rocking. The wire insulation stretches but the wires don't and break, so you could have a bad wire but it won't be visible.
+1!!!!! I was thinking the same thing and consistent with the code. Probably intermittent connection and when you get on it, it pulls the wires a part and kills the injector.
CB
Old 06-29-2009, 12:00 AM
jackyl's Avatar
jackyl
jackyl is offline
Originally Posted by rambobob
Just walked in the door. 3 shots of anejo teq and I am feeling better. Bike is sputtering and will not run under load. Checked spark plugs, all fuses, new gas, battery terminal was a little loose , fixed that. riding 250 miles to get home. Engine light comes on and off. Everything seems fine but runs like sh-----t. Any Ideas. Guess its going to the stealer soon. could not find any loose connections . Any ideas , Thanks.
charge your battery, if it isnt full charge it will effect the efi and makes the bike sputter badly, trust me. jackyl
Old 06-29-2009, 06:28 AM
shimmon's Avatar
shimmon
shimmon is offline
this sounds similar to a problem i had... was thinking it was the Idle Air Controller also. but i never had any diagnostic codes. i would venture to say it was either caused by your loose battery connection, which you already corrected. or also as said above, the rear injector wire was is broken inside insulation, if you run your bike and try and move the wires around, you may get it to cut out. if so, repair or replace.
Old 06-29-2009, 06:23 PM
rambobob's Avatar
rambobob
rambobob is offline
Thanks again, just trying to find time to troubleshoot.
Old 06-29-2009, 06:32 PM
rambobob's Avatar
rambobob
rambobob is offline
I checked the codes to make sure there were not anymore. No more. Did get Pn 176 5003- is that a part #?
Old 06-29-2009, 07:33 PM
man4mopar's Avatar
man4mopar
man4mopar is offline
I don't know what that part# is you listed since not at home or in front of my manuals.
Like already mentioned check the wiring to your rear injector very closely. Mine and some others have had the wire brake inside the insulator.
Here is my post with pics. Had the same code as you and symptoms.
https://www.hdforums.com/forum/dyna-...you-later.html
Old 06-29-2009, 08:08 PM
rambobob's Avatar
rambobob
rambobob is offline
I took the battery out and charged it. did not take but 15 min for full charge. Not the battery.
Also pulled seat to check under. Nothing I could see.
Injectors hard to get to, did not want to pull tank tonight.
Old 06-29-2009, 08:32 PM
the blob's Avatar
the blob
the blob is offline
yea sounds like the injector wires due to the open inj.code.
Old 06-29-2009, 08:54 PM
rambobob's Avatar
rambobob
rambobob is offline
Ok, started bike, let run while playing with wires around injectors. Was able to get it to idle faster and rougher while playing with wires. Can't tell if its the injector wire or wire going into top of throttle body. Time for bed.
Old 06-29-2009, 09:13 PM
rambobob's Avatar
rambobob
rambobob is offline
Looks like wires going into Map sensor???
Quick Reply: Help, Barely made it home . Bike sputtering.
