Painted lowers, thanks JRK!! PICS!!
Old 06-20-2009 | 04:00 PM
JaronB's Avatar
JaronB
Default Painted lowers, thanks JRK!! PICS!!
Well I have finally decided to put the Appliance Epoxy to the test. Hand sanding really shows you where they cheeped out on the clear. The front I had to work pretty good on. On the back the clear came right off. Used JRK's thread from earlier this month for the process. Started with 220, ended with 400grit. Washed and painted, it was easy. I have a couple runs on the back side of one tube, but not to big a deal. I blame the impatients I have!! Here's what I got. Once it cures for a couple hours I'll put it back together and post more pics.
with 220 grit
with 400 grit
and painted
Old 06-20-2009 | 04:08 PM
moosh's Avatar
moosh
looks good and you did it yourself
Old 06-20-2009 | 04:10 PM
JaronB's Avatar
JaronB
Yup in my garage!! That appliance Epoxy is amazing. About an hour for each tube of sanding! 5 min wash and blew off with air compressor. Painted within 30min!! Make sure you cover everything because this stuff gets all over. Here's JRK's write up that I used!
https://www.hdforums.com/forum/dyna-...ower-legs.html
Old 06-20-2009 | 04:22 PM
maddghost's Avatar
maddghost
Looks fresh from the factory!
Don51's Avatar
Don51
The lowers came out real nice!! Good job.
Old 06-20-2009 | 04:30 PM
JaronB's Avatar
JaronB
Old 06-20-2009 | 04:43 PM
Coxbow's Avatar
Coxbow
Old 06-20-2009 | 05:55 PM
JaronB's Avatar
JaronB
oops!! looks like I copied my inbox!! I edited it above and here it is again.
Old 06-20-2009 | 05:57 PM
Coxbow's Avatar
Coxbow
I've found it myself like a big boy
thanks
Old 06-20-2009 | 06:36 PM
url8's Avatar
url8
Looks great, Nice job!!
Quick Reply: Painted lowers, thanks JRK!! PICS!!
