when checking rear belt deflection
The '09 service manual for Dynas gives two specs for the belt adjustment, on the jiffy stand with no load on the bike, or vehicle upright with the rear wheel in the air.
Jiffy stand FXDF/FXD/FXDC 5/16 - 3/8"
in air 1/2 - 9/16"
Jiffy stand FXDB/FXDL 1/4 - 5/16"
in air 5/16 - 3/8"
measured with 10 lbs force at the deflection viewing window.
in air 1/2 - 9/16"
in air 5/16 - 3/8"
01 Wide Glide you check the belt with the approximate weight you normally ride with. If you normally ride 1 up, then the weight should be yours, if you ride 2 up, take that into consideration when making adjustments.
Again this is for an 01 Wide Glide, and things do change....
Respects,
Ed
Respects,
Ed
measured on the ground with an equal number of turns on the belt tension adjustment bolts
man i just saved a bundle my 07 streetbob , my 5000 mile service calls for,replacing engine oil and filter inspect and service air cleaner as needed check tire pressure and tread, check wheel spoke tightness do clutch adjustment inspect adjust rear belt and sprocket
check adjust and lubricate throttle brake and clutch controls
inspect fuel lines for leaks
check brake fluid inspect brake pads for wear
check operation of electrical components and switches
all this cost me 20 dollars for oil and filter, and my time
i have two harley shops in town one was 170.00 bucks and the other was 275.00
i love my manual and the help here
freebyrd
freebyrd
I'm just a rebel I guess. I check my belt tension by parking the bike on the kick-stand in neutral, then grabbing the belt between my thumb and index finger and wiggling it up and down. If it feels too tight (like it did when I got it new from the dealer) then I loosen it up. If it feels too loose then I tighten it up. My wiggle test has gotten me through almost 20,000 miles of riding on bikes with drive belts with zero problems. So far so good... crucify me.
![Icon Goofygrin](https://www.hdforums.com/forum/images/smilies/icon_goofygrin.gif)
