when checking rear belt deflection
FWIW, once you adjust your belt at the 5000 mile service it stretches very little more than the initial break in. Some guys wait until 10-15k or tire replacement to adjust it if it is not making noise. Me, I do all the wheel maintenance when it is tire time unless I have an issue.
Rear tire: Belt adjustment, swingarm bearing check, rear brake pads if they are over 70% gone, rear rotor check.
Front tire: Brake pads, fork oil, bearing check, steering head & fallaway adjustment.
I just figure if you are getting in there...why do it all over again?
