here's my question, which is the longer of the two? i removed both the throttle and idle cables about a week ago and didn't mark the two. right now i'm trying to reinstall them both and don't want to mess up by putting them on the wrong one.i tried to search the threads here, but i had no luck. any help with re-installation would be appreciated.
I believe they are push pull and you should be able to determine which is which just by manually pulling each. Only one will give you travel since the throttle body should be closed. That is your main throttle cable, the other is the return.
One of your cables should have a little spring on it, at the end where it inserts into the mount on your throttle body. The cable with the spring on it, is your idle cable.
