HELP! Fatbob will not start
Old 06-17-2009 | 04:34 PM
maddghost's Avatar
maddghost
My pcV had a big problem right after ai washed it once. I would check that if the plugs look fine. Also there was another member last week who had a small wire disconnected from the bottom of the box where the plug wires come from.
Old 06-18-2009 | 04:19 PM
kdawgmfic's Avatar
kdawgmfic
One more thing, if you've disconnected your fuel line since last start for whatever reason, check and make sure it's fully connected. I pulled mine off once and put it back on, crank but would not start. I just didn't connect it all the way, I pushed it up, it stayed, but it wanted another 1/8 inch up to lock it on.
william kennedy
06-18-2019 10:19 PM
Huckster
04-07-2017 01:04 PM
PigInaBlanket
02-19-2013 10:08 PM
basarabz
12-15-2007 07:21 PM
Bent Carhood
12-02-2007 07:38 PM
