poly engine mounts?
It probably would compared to a new rubber mount, but that would be OK as long as it holds up, I doubt the vibes would be worse then they are with the engine setting metal to metal with the saggy old rubber isolator
Glide-Pro was supposedly going to make one but I don't believe they followed through on it?
Here is a thread that talked about the engine mounts.
https://www.hdforums.com/forum/dyna-...or-mounts.html
CB
CB
thanks for old vib link thread ref
CB
CB
If you're replacing the mounts then there is a problem with the mounts you're buying. I'm certain there was a thread discussing the front isolator. Some of them were made wrong, and transmitted a ton of vibes through the chassis. I'll see if I can find it.
Here it is...
https://www.hdforums.com/forum/dyna-...ixed-pics.html
Here it is...
CB
Yellotang
09-18-2007 09:29 PM
