Questions WRT Heads
Questions WRT Heads
For those who've had head work done:
- What did you have done? (Port, polish, new valves, valve springs, rocker arms/roller rockers, etc.)
- What did you pay?
- Are you happy with the results? (What else have you done to the motor?)
For those who've replaced your heads:
- What did you go with? (Screamin' Eagle, S&S, Jim's, Ultima, etc.)
- What did you pay?
I'm interested in doing some work on my motor after I get back from deployment and am seriously leaning toward doing heads and cams ... I'd like to compare notes and see what others have done and the results.
R/
Chop (fka "Priest")
- What did you pay?
- What did you pay?
R/
Chop (fka "Priest")
R&R TC stage 5 cast heads- they sell over your way for $1400 or so.
Andrews 60H cams
Horsepower Inc 55mm t/body
D&D fatcat 2-1 exhaust
Delkron +.030 rocker support plates
SE Roller rockers, SE premium tapered p/rods
3.938" JE pistons
11.64 down the 1/4, with soft starts and clutch shifts.
Andrews 60H cams
3.938" JE pistons
CNC WHEEL GUY
08-09-2009 09:20 AM
