Sputhe Positrac Front
The Spruthe Positrak, and others like it (True-Trak), locks or ties the engine to the frame so that this side load can only be applied in the vertical plane, thus eliminating the "twitch".
Hope this helps.
The swing arm is bolted to a rubber mounted engine, and transmission. The rubber engine and trans mounts allow side to side and up and down motion. Since the swingarm is rubber mounted via the transmission, the rear wheel and swing arm will move side to side when you throttle it out of a corner causing a very wierd feel. The sputhe and truetrac eliminate the side to side motion and keep the engine, trans and swing arm in line with the frame eliminating the rear wheel wander. Something HD should have done, and they know it!
Same thing dlstanf2 said, I just dumbed it up.
when exceeding 60 mph in turns. Feels like the rear is following really badly lined up rain grooves. Have not noticed it AT ALL on tight radius turns up to the said 60 mph. I ride pretty aggressively (for a cruiser) and my engine puts out plenty more steam than stock (about +67% more) which would surely test the mounting system of my Dyna.
The photos of the Harley are with the stock Harley motor mount, the bike handled as if on rails......... below 60 mph.
riding other bikes semi-aggressively ....
I have noticed the wandering, self steering rear end on my Dyna, ONLY
You're killin' it on that Aprilla!
I love my True Track, I'll never take it off. It really helps with speedy cornering
ek1
09-04-2013 07:41 PM
