Satellite radio install
Old 06-10-2009, 12:22 PM
GREENOHAWK69's Avatar
GREENOHAWK69
GREENOHAWK69 is offline
Originally Posted by dbcoooper
Guys I installed a stilleto II. There was no L shaped bracket in the box. I am thinking the best place for it is on top of the brake fluid res... thinking maybe some stick tac as there there is no magnetic connection there.
db
I would suggest going back to where you purchased your radio or call customer service and explain to them that you don't have a "L" bracket. I purchased to cycle radio kits and they both came with an "L" bracket, as well as, the flat bracket you have installed.
I have the Sirius ST4 model.
Old 06-10-2009, 01:28 PM
JRK5892's Avatar
JRK5892
JRK5892 is offline
I usually run them along the upper tubes, down the front town tube, or on the touring bikes just along the fender rails... works great. i would show you pics but i simply have never taken any!
Old 06-11-2009, 11:20 PM
dbcoooper's Avatar
dbcoooper
dbcoooper is offline
Originally Posted by TIDE
They have antenna headphones. You could wear it on your head. I was thinking of getting the stilletto 2 but I didnt want to deal with the antenna and I want a kick *** amp and speakers to go with it.
The head phones are kinda big and bulky. I use the buds because I doubt I could hear any sound over the wind and pipes... maybe if it was cranked up
db
Old 06-11-2009, 11:27 PM
dbcoooper's Avatar
dbcoooper
Originally Posted by jcopel
I have the stilletto II with the antenna headphones. You can plug earbuds (or speakers) into the stilletto along with the antenna headphones. I wear a helmet with the earbuds and placed the antenna headphones around my neck with the antenna to the back of my neck. It picked up fine. If you mount the stiletto to your bike, you may be able to mount the headphone antenna to the top of a fork bag or sissy bar.
I found an inexpensive handlebar mount for an ipod at this website - www.mountguys.com. They do a lot of custom stuff - they might make something for your setup.
not sure of your set up but I tried that and found that I could not pick up a signal with the radio attached to the car kit using the head phones as an antenna. Not sure why. Works great with the car kit though.
Old 06-12-2009, 01:12 PM
jcopel's Avatar
jcopel
jcopel is offline
Mine was not attached to the car kit when I've used it on the bike. My antenna hadphones have the rectangular shaped plug in that will not plug into my car kit. I actually used this on my Sporty that did not have a sissy bar at all, but with the backrest pad on my Dyna, I can bungy the antenna (headphones) to the back rest and use my earbuds to listen.
Does yours look like this? Actually, I just realized that I have the Stilletto 100...
Attached Thumbnails Satellite radio install-pict4814.jpg   Satellite radio install-pict4818.jpg   Satellite radio install-pict4820.jpg
Old 06-13-2009, 01:37 AM
dbcoooper's Avatar
dbcoooper
The head phones are the same but I still get lousy reception using them... I also wanted to make use of the powerlet set up I bought, so I went with the car kit install. It was super easy to install, just having trouble locating the antenna.
db
Rufnek100
Audio Systems
09-20-2018 07:27 PM
Notch2005
Audio Systems
12-15-2013 04:31 PM
cybricon
09-08-2012 04:11 PM
riteway
04-16-2008 11:19 PM
TRTSTREET
04-28-2007 11:58 PM
Quick Reply: Satellite radio install
